Results 1 to 5 of 5
10-13-2009 08:50 PM #1
ayuda para programar beeper de fabrica de matrix
esa es una de las ayudas yo quisiera saber tambn si alguien aqui tiene una matrix xrs pq quiero saber si son como la mia que es bn baga arrancando pero en alta me corre bn yo pensaba reparar el motor pero no c que hacer.
10-13-2009 10:00 PM #2
Re: ayuda para programar beeper de fabrica de matrix
yeah it should work I just did my '07 TRIX XR... the dealer told me that I should just bring it in and I be charged like $80, so I did it and no problem like 2 minutes.... here are the instructions:
Para configurar alarma, esta en ingles.
make sure the code on the back of teh remote is as follows: US Code: FCC ID: GQ43VT14T
Canada: 1470 102 849
This worked like a charm....
2003 - 2006 TOYOTA Matrix Programming Instructions
Programming Procedure:
To Program Wireless Transmitters:
1. Begin with:
The driver's door open and unlocked.
Key out of the ignition.
2. Insert and remove the key from the ignition switch 2 times within 5 seconds.
3. Close and open driver's door TWICE within 40 seconds.
4. Insert the key into the ignition and remove it.
5. Close and open the driver's door TWICE within 40 seconds.
6. Insert the key into the ignition.
7. Close the door.
8. Turn the ignition switch from "Lock" to "On" and back to "Lock" at about 1 second intervals to select the desired mode.
1 time for ADD mode.
2 times for REWRITE mode.
3 times for CONFIRMATION mode. .
5 times for PROHIBITION mode.
9. Remove the key from the ignition.
10. To confirm your mode selection, the power locks will now cycle “lock” to “unlock a
number of times corresponding to your key cycles in step 8.
If Confirmation or Prohibition modes have been selected, opening the door will
complete the procedure.
11. For Add or Rewrite modes, within 40 seconds of Door Lock confirmation...
A. Press both transmitter Lock and Unlock buttons simultaneously 1 second and release.
B. Within 3 seconds of step A, press the transmitter Lock button for 2
seconds and release.
C. If the transmitter has been successfully programmed, the power locks will cycle
“Lock" to “Unlock" ONCE at this time. If there are problems with the
procedure up to this point, the locks will cycle TWICE. If this occurs, verify that
you have received the correct transmitter, and then repeat the above procedure.
D. If multiple remotes are to be reprogrammed, repeat steps A-C.
12. Open the Driver’s door
NOTE: CLOSE THE DOOR BEFORE TESTING REMOTE.
10-14-2009 06:11 PM #3
muchisimas gracias te lo agradesco un monton
10-16-2009 10:01 AM #4
10-17-2009 07:30 AM #5
son asi y mas si le tienes aros grandes la mia esta con los aros de fabrica y son asi medias baguitas pero te diria que desdpues de las 3mil corre = que otro carro despues de las 6mil es otro mundo pero arrancando son baguitas asi que no agas na vas a perder el tiempo y los $$
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
